A129 Pro blocking key fob signal
kleanphil
G.C
This is an issue reported on another website by some one else. I thought maybe some one here has had a similar issue.
The person who posted this issue claims that when he disconnects the rear camera the problem goes away
It is possible, here are several threads reporting interference (keyfobs, FM/DAB radio, etc.) from the USB cable between cameras. That's probably why Viofo started using coax cables with serialized communication.
Some use ferrite beads on both ends and claimed it helped. I'm rather from "use better power supply, because some initial versions of HWK suck big time" team.
The guy received some ferrite beads from Viofo which fixed the issue (y)
I am having the same issue. Where my key fob range suddenly went down. I am going to order ferrite bead on amazon
