There have been some complaints about this elsewhere. Looks like it's working, even announces it is recording and how many channels. I'm hoping a FW update rectifies it and the HDR Auto issue.hm I just got back from doing some nighttime driving testing and only one of my A139 Pro's were recording. Bummer since it means I have to redo the whole drive again to get my comparison footage. I'm not sure what happened, but I verified that it was on via the LED's, but I guess I didn't look closely enough to see that the record LED was solid. One of the downsides of having the audio beeps disabled I guess.
Can you share this test FW, because still no official updates available?I recently tested a test firmware I was given to see if the problem I ran into was fixed and it was. The next production firmware release for the A139 Pro should have the HDR Timer feature working correctly.
I will check with VIOFO and see if I can share this test version.Can you share this test FW, because still no official updates available?
VIOFO gave me permission to share the Google Drive link for the beta/test firmware v1.0_0206 for the A139 Pro which addresses the "HDR Timer" problems.Can you share this test FW, because still no official updates available?
If your A139 Pro is failing to write to the microSD or freezing, then it might be worthwhile to try the beta/test firmware v1.0_0206. I was able to get around the problems with the current production firmware v1.0_1217 by setting the HDR setting to Off or On instead of Auto. There appear to be a few additional fixes in the soon to be released update for the A139 Pro firmware. The beta/test firmware v1.0_0206 seemed to resolve the case when the HDR setting was set to Auto.I'm so glad I found this forum. I ordered the A139PRO last week and when I saw this post, my heart sank. I hope my unit will be okay. This is my first dash cam purchase, so I'm still learning. I'm surprised there are so many bugs with dashcams. I thought it was just plug and play
Do you think it's worth waiting for the official VIAFO release of the latest firmware, or go with the beta version (v1.0_0206)?
Thanks for the advice. I'll be sure to set HDR to ON and go from there. Appreciate your help!If your A139 Pro is failing to write to the microSD or freezing, then it might be worthwhile to try the beta/test firmware v1.0_0206. I was able to get around the problems with the current production firmware v1.0_1217 by setting the HDR setting to Off or On instead of Auto. There appear to be a few additional fixes in the soon to be released update for the A139 Pro firmware. The beta/test firmware v1.0_0206 seemed to resolve the case when the HDR setting was set to Auto.
Once in a while I have this problem with my A129 Pro 2CH. Beeps and asks me if I want to delete something. WTH? Weird. Seems completely random. I unplug it, then plug it back in, then everything is fine. I hope I don't have this nonsense with the A139 Pro.
doesn't really help us to help you.Beeps and asks me if I want to delete something.
I'd suggest as a test, try a different memory card for a little bit and see if the problem goes away. Anything wonky with your memory card might cause transient storage errors that make the dashcam think the card is full. Do you have it set to overwrite old files automatically?Once in a while I have this problem with my A129 Pro 2CH. Beeps and asks me if I want to delete something. WTH? Weird. Seems completely random. I unplug it, then plug it back in, then everything is fine. I hope I don't have this nonsense with the A139 Pro.
Good idea but the error is so rare that I don't know if it'll be worth it to troubleshoot with a different memory card. I'm going to try formatting the card though, as I just saw that VIOFO recommends occassionally formatting the card. I've never re-formatted the card. Yes, I have it set to overwrite old files automatically.I'd suggest as a test, try a different memory card for a little bit and see if the problem goes away. Anything wonky with your memory card might cause transient storage errors that make the dashcam think the card is full. Do you have it set to overwrite old files automatically?
