SawMaster
- Apr 10, 2015
- SC
- Numerous and ever-changing
Check all the coax connections to see if they all have the same amount of 'wobble' and to see if they are all 'clicking' into place similarly. Cam should be turned off for this test. If one coax connection (either end) on the rear cam circuit seems significantly looser then the others, that will be where your problem is at. Then try a coax end which fits tightly elsewhere at the loose connection; if it is now tight the coax is bad. If it is still loose the coax socket in the cam is likely bad. Especially with these small coax cables the odds are that it's a bad cable, but there's a lot of stress on the socket where it mounts to the PCB so could be either one I guess. A much smaller chance is the coax got crimped or kinked at some point.
