MedicalFlyer
- Feb 10, 2015
- United Kingdom
- Mobius C Lens, Mini 0906, SG9663DC Pro, A229 Plus
Dodging the sporadic rain today I got my cam installed in the car. Just need to fiddle with the settings when I go for a drive but all seems to be fine so far.
Was fairly easy to install other than getting the rear cam cable through the existing tubing for the tailgate (always an absolute pain and I very slightly damaged the connector but no harm done). With all the sensor units on the windscreen already I was a bit limited for mounting positions and the front view is a little off to the left as a result but still sees everything going on.
I must say the static plastic is a great touch. If it ever comes to removing it at least I won't be picking bits of 3M of the windscreen for hours.
The HW4 kit and fuse taps could really do with having bullet connectors like the SG stuff used to as needing to crimp it on is a pain when you only have various wire cutters to hand. I might go back in and solder them properly instead one day.
The included wires are certainly more than long enough for most cases I'd say. Mine all goes inside the roof lining and down the A-pillar. The rear goes down the A-pillar enough to pass behind the airbag and then off along the roof lining out the way of the airbags and of in to the roof lining over the boot. All of the excess was loosely wound and hidden in the roof out the way.
