Advice needed please
ChrisI
I recently purchased a Blueskysea B40/A118 Novatek 96650 Dashcam through Amazon UK. The actual supplier was Coshine group based in China.
The first camera had what I assumed to be a fault in that the TF card could not be clipped into place and slid out of the slot. Holding the card in position had no effect and if pushed slightly harder the camera turned off. I tried another TF card but with the same result. The second card I had purchased on e bay as a 64gb card but on checking its capacity using H2testw it was shown to be faulty with a capacity of 4GB so this card must be regarded as questionable. The first card that I used I purchased from Amazon and it is a Kingston 32GB class 10 that checks ok on the test.
I assumed the camera to be faulty and returned it and have now received a replacement but I am still unable to get the replacement camera to hold the TF card in place and am unable to record.
The camera will start with the welcome screen and I can access the menu functions without a problem.
If I press record the camera says "insert TF card" I insert the card with the writing facing the TF on the camera and the hook on the card on the mic side. If I push and hold the card its says goodbye and turns off.
If I push & hold the card all the way in, power up and then press record the red record light flashes and there is a red flashing dot on the top line of the screen between the camera icon and HDR the timer on the top line starts counting. if I stop holding the card it wishes me goodbye and turns off.
4 Questions :
1)Am I unlucky and have received 2 dud cameras
2) Should I return the second camera and get a refund
2) Is it my TF card that is faulty?
3) Am I doing something stupid and screwing it up?
Any advice gratefully received.
Thanks Chris
Your micro SD card should only go in one way and should click into place. If it doesn't, write the seller for sure and tell them you've had enough wasting time.
I got mine from the same people ( i am waiting for them to resolve a problem with the gps setting my time 8 hrs ahead )
like most micro sd sockets you should feel it click into place and its sprung loaded so you push it in to release it
when you put your card in dose it go in flush?
If not try turning the card round and putting it in the other way ... off the top of my head you should see the connectors facing you as you insert it.
I know thats obvious stuff sorry
This is why i got mine
You have confirmed what I thought but was unsure as both cameras appear to have the same problem.
I then thought it was something that I was doing.
You are right. It is obvious which is why I could not understand the same problem on two different cameras. Everything that I have every purchased using an SD card clicks into place.
All the write ups indicate that this camera is discreet on the windshield and provides great pictures at a very reasonable cost.
However it also seems that there are some fake and second grade sllers around. I had hope that by using Amazon that I would avoid these problems but obvioulsy not!!
Thanks for your advice
Select from menu settings time zone: GMT +0 for UK, then it should be fine.
That option is missing from my unit
i am waiting for a firmware update from them
Roj,
I too have the same problem. I bought mine through Ebay, a B40 with Blueskysea logo on the startup screen.
B40.20140806.001
I have asked for an updated firmware to add "TimeZone" I believe it's falling on deaf ears. So I just leave the GPS unplugged, so IF I get into an accident, at least I will have a picture with the correct time on it. I'll just give them a negative review.
In the interim I'd suggest turning the OSD time & date off so it's not embedded in the video, you can then use the time offset setting in Registrator Viewer to correct things, if needed you can create a subtitle file with Registrator Viewer with corrected offset
I know that's obvious stuff sorry
Roj,
I finally pulled the plug on this company, Coshine. The way they answer my "Where's the firmware" with DUH if you change firmware you could make a brick. Well folks, not if it's good firmware. Yes, you can have a botched install, but there are enough good folks on this forum to help.
As for those thinking about buying from Cosine, Caveat Emptor "Let the buyer beware".
there's a couple of hardware versions and the reason these sellers are reluctant to have you update firmware is because very often they don't know which version they're selling and it can change from order to order, they get stock from unofficial channels and they get what they get
