I recently purchased a Blueskysea B40/A118 Novatek 96650 Dashcam through Amazon UK. The actual supplier was Coshine group based in China.
The first camera had what I assumed to be a fault in that the TF card could not be clipped into place and slid out of the slot. Holding the card in position had no effect and if pushed slightly harder the camera turned off. I tried another TF card but with the same result. The second card I had purchased on e bay as a 64gb card but on checking its capacity using H2testw it was shown to be faulty with a capacity of 4GB so this card must be regarded as questionable. The first card that I used I purchased from Amazon and it is a Kingston 32GB class 10 that checks ok on the test.
I assumed the camera to be faulty and returned it and have now received a replacement but I am still unable to get the replacement camera to hold the TF card in place and am unable to record.
The camera will start with the welcome screen and I can access the menu functions without a problem.
If I press record the camera says "insert TF card" I insert the card with the writing facing the TF on the camera and the hook on the card on the mic side. If I push and hold the card its says goodbye and turns off.
If I push & hold the card all the way in, power up and then press record the red record light flashes and there is a red flashing dot on the top line of the screen between the camera icon and HDR the timer on the top line starts counting. if I stop holding the card it wishes me goodbye and turns off.
4 Questions :
1)Am I unlucky and have received 2 dud cameras
2) Should I return the second camera and get a refund
2) Is it my TF card that is faulty?
3) Am I doing something stupid and screwing it up?
Any advice gratefully received.
Thanks Chris
4 Questions :
Thanks Chris
