Andy Moore
- Mar 4, 2015
- United Kingdom
Running V1009...........apart from its over-sensitive motion detection
tl;dr: Not perfect but a lot better with custom FW
I did a post here https://dashcamtalk.com/forum/threa...er-picture-seems-below-par.16962/#post-220722 and here https://dashcamtalk.com/forum/threads/blackvue-dr650gw-2ch-_-custom-firmware.9423/page-7#post-220848https://dashcamtalk.com/forum/threa...er-picture-seems-below-par.16962/#post-220722Which custom firmware you use and where did you get it?
Yes, If the camera was made in April 2015 or later it will not work with the custom firmware....but the rear camera may or may not work.
I would say video is good just not what i expected from a sub £300 dash cam (high expectations)Hmm.. so we get:
- Night video not good
- Daytime video have lots of pixelation (can only be solved with custom FW, but rear camera stopped working)
- Sensitivity is too sensitive, even with level 0 setting
- Brightness... per the above.
I just had the BlackVue installed yesterday, so haven't seen the night video. I know that day video is REALLY bad compared to my $60 G1W. Have not tried the Parking Mode yet, so haven't tried the sensitivity settings.
It does have some issues but these can be sorted with camera position and adjustment. Problem is you only get two stick pads. Don't get it right 1st time and your stuck with your 2nd attempt.
Yeah my 1st attempt i totally forgot about the window wipers and their reach. Put it too high (it was good because you couldn't see it from outside) but when it rained the droplets where not wiped away.I found the best way is to connect it to your phone via WiFi and have the live preview on then offer the camera up to the window. When you are happy with the picture you can then take the sticky pad protection cover off and apply to the windscreen. Possibly one of the advantages of this camera
So we strongly recommend emailing your feedback directly at sales@pittasoft.com or on their facebook page.
https://www.dropbox.com/sh/f1lhtdog5ei3wr6/AABNRkpaOJhj8RiE1xsPCtZta?dl=0
some raw footage. The night videos look even worse on this one which may be caused by the torrential rain we are having at the moment
