Webcam Mode There are two ways in which you can enter webcam mode. Method 1: • Connect the camera as a removable drive (see above). • Press the Shutter button to enter webcam mode. • ► If this is the first time you have connected the camera in WebCam mode, Windows will automatically install the required drivers. • ► Disconnect the camera or press the Power button to exit webcam mode. Method 2: • Remove the flash memory card. • Connect the camera to the PC using a standard USB cable. • The yellow LED will blink at 2 second intervals indicating there is no card inserted. This is normal. • ► If this is the first time you have connected the camera in WebCam mode, Windows will automatically install the required drivers. • The camera is now in Webcam mode. • Start your favorite WebCam software, such as AMCap. If your screen is black, the software is not configured correctly. Make sure the program shows the "USB PC camera" as the "device" selected for video capture. If this option does not show in the "device" option list, restart the webcam program and check again. • Disconnect the camera or press the Power button to exit webcam mode. ►Note: Windows XP has an integrated WebCam viewer. Your Mobius should be visible in Explorer (My Computer) as a "USB Video Device". This functionality does not exist in Windows 7
