Passion 4 Pro
- Nov 8, 2013
- China
Like loop recording? If there is no "delay", would be cool~
Or taking a long-time-video?
Thanks for your reminder. I just want to get some idea about the normal way the "motion detection" function works, absolutely including the DIMIKA right here in this thread.You asjing about Dimika loop rec or Pano2? If Pano2 then lets talk about it in Powerucc thread, otherwise it will get messy here ( Dimika thread )
Usually with most other dash cams when motion is detected, then it starts revording for certain period which determined by firmware. Some records 10sec after motion is gone, some 30sec / 1min etc.
For Dimika motion det rec can be set up only via PC. Another words if you are on thr go and using normal rec mode then you will not be able to set it to motion det rec.
Only can be set up via PC? Sounds a little bit inconvenient...
I am also interested in the video quality for this mode, I personally prefer 1080P.
Read user manual
http://dimikacamera.com/dimika-user-manual/
5.3 When the camera captures mobile objects within 3 meters, it will start to record a 10-second-long video, and then save the file automatically, standby for next motion.
Is 10 seconds too short or not? I think a little bit longer will be better.
Sound good! I like this function pretty much. Already thinking some idea to play with it.😎that depends, 10 sec is not long but if the motion continues then so does the recording and it should stop 10 secs after the motion ends
Haha, you may use it for ghost spotting.Sound good! I like this function pretty much. Already thinking some idea to play with it.😎
