kinonotabi
- Jan 2, 2018
- Indonesia
- Junsun MT8127
Hi,
I have problem with my dashcam that can not loop in recording.
My device is Junsun MT8127 Something - Errr ... I don't exactly know its real name but I attached the picture of it
It has worked good for many functions under android OS 4.4.2 with its own interface that different from common android UI.
But not so for GPS, It is an offline iGO with outdated map which cannot reach online for searching location nor update apllication.
So I installed Waze for online GPS in it.
Unfortunately with its distinctive UI it doesn't have Google play store installed thus I installed play store application with its companion (google play service and Google Map).
With google play store it can installed Waze normally and working flawlessly.
Somehow when I start recording with its own DVR application (Others play stores dashcam application can not recognize the device) it can not loop recording.
When it had shortage storage in SD Card the application's notification appears and needed to manually confirm to erase ALL recording files.
That would negates the dashcam function to operate automatically without human interference and can re-write old files or loop recording.
I had contact the seller and he suggest me to deactivate detection crash function or made it sensor at low sensitivity but the problem is still there.
Too bad I was not tried dashcam loop before I installed Google play store and others application, so I don't know whether it's exist before or not.
And when google applications installed it can be uninstalled without reseting the devices to factory setting.
At this point I hesitate to do so before get clear answer from seller it can normally work again after resetting because it use distinct UI than common Android OS.
It might losing some crucial application ... I don't know?
So, that's the background of my troubled dashcam loop.
If any members had experienced with this problem or know some clues please help me to solved it.
Thank you
Thank you
