AV OUT CABLE?
Chuck Wallace
Mechanicsville Virginia
He's back. Looking thru the users manual and some search on site, but not finding what cable to use from the av out port to a monitor or tablet and where to get one. Saw on another brand site jokiin told someone a 3.5 mm to 2x rca lead for that brand. Anyone here know for sure? Thanks.
..... Saw on another brand site jokiin told someone a 3.5 mm to 2x rca lead for that brand. Anyone here know for sure? Thanks.
I am using a Canon camera mono audio/video cable. You can use any cable which have: audio on top, second also audio if stereo, third video, ground at the base.
How is playback performance using the dashcam direct to a monitor ?
Not sure, I am using a small resolution display that helps a lot to verify the position of the camera.
I only ask because there have been lots of posts where the answer was to move the .mov files to the PC hard drive to enable smooth playback.
Suitable 4 pin AV connector 3.5 mm jack / TRRS AV-TV out / Composite A/V Cable 3×RCA-TRRS
For example, two circuits are shown, the video signal and ground contacts are unchanged.
When you connect a mini-jack, the Viofo A119 V3 screen turns off, the image is displayed on the remote monitor
PS: I just checked the cable that was "on hand"
View attachment 51716 View attachment 51718
Thanks. Now if Best Buy can open maybe? they can sell the right part.
AV to 3.5mm Cable - Multi
Only such a cable was found there (this one is more convenient, because the jack connector is made by an angle),
but you probably have to purchase another adapter - for the correct connection of video: Male to Male RCA Connector Adapter
PS: Although there are such cables:
but you can hardly find it on sale
