Just curious about the AV Out Plug.
Has anyone ever used it on this mode or previous A119's?
If it does have an output can it be inputted to your phone or dash screen?
It is a ANALOGUE AV output with a standard 3.5mm plug port at the camera. You would use it to connect the camera to any device that accepts an analogue audio/video input such as a TV monitor using a 3.5mm phone plug to RCA cable. So you could probably connect it to the head unit in your car but it won't connect directly to a smartphone. In all likelihood the AV video output from the camera will have a 4:3 image ratio (SD-standard definition) rather than the 16:9 ratio (HD-high definintion) you see in your dash cam videos.
So the image isn't 4:3 after all. That's great! Many other dash cams I've seen with AV out default to 4:3 rather than 16:9. The Mobius camera provides a choice for AV display ratio (4:3 or 16:9), one of the few that does that.
Hummm. I have an extra channel input to my motorhome side and back camera screen in the dash.
May have to see if I can plug it into that. That would be nice.
