B40 Capacitor version
Thanks jokiin.
I'll hold out for a few weeks then. The A118C is $75 I'm hoping your version is still sub $100!
it won't be, ours is different hardware, also keep in mind ours comes with GPS and 32GB memory card, add those to the A118C and it's also over $100
I understand you running different hardware that's why I'm waiting.
I would like it without GPS, unless it's built in or needed for the parking mode.
we aren't doing a non GPS version at this stage, we need it for some of the functionality, I'm not sure a stripped down version really makes sense considering the extra hardware expense though
Also is the GPS unit still mounting to the Dash (for all to see) like the original SG9665GM or the windshield?
They are intended to go on the dash, if you're keen you could open the GPS and flip the internals inside the housing and stick it to the window, not hard to do
Received mine A118C today, firmware version is 20150108. I'm using cigarette lighter socket for powering it and every time when I don't start the engine within approx 10 seconds after turning the ignition key into "ACC" position, the cam just turns off upon starting the engine and stays off.
Here's what happens I believe: cam waits for 10 seconds expecting that car will be started within that time in order to cope with expected temporary power loss on the socket (power on cigarette socket goes off while starting the car as well as radio/CD player etc. But if car is started after a delay longer than that (say, I listened to the radio for a while before starting the engine), cam detects temporary power loss on the socket and turns itself off immediately thinking that ignition went off. Unfortunately it does not detect that power is back on within a second and this results in driving with a cam that's switched off!
Not sure if that can be tweaked with firmware upgrade but it's a big drawback on this cam at the moment - you can't be sure it will be recording when you expect it to.
I'll try to look for +12 that does not turn off while starting but is still very annoying as there was no such issue on A118 battery version. Be aware!
Foxoffer, but would not be surprised to see that all A118C's from other sellers behave the same way...
Good to know. I've only been reading on the forum for a month. I read where some Chinese cameras such as the G1w series are made by several manufacturers, with varying quality, and assumed that was also the case with the A118C's. I have 2 that are in shipping from GearBest right now and will let you know if I experience the same problem. I don't expect to have them for several more weeks though.
If your car cuts power for an excessive amount of time and you switch the ignition on but don't start it until after the camera has started it will do the same thing, if you want to sit with the radio on then better to key off before starting the car
Just curious - what is the functionality the GPS will be used for besides obtaining position?
Perfect, I was hoping for this - time and date being maintained by GPS. For me it's much more important than the position. 🙂
You need to rewire the power for the camera to an ignition "ON" source, not an "ACC" source. Mine is wired to my Gentex mirror, which only turns on when the key is "ON". You should be able to find a source like that in the fuse box, i.e. wipers or fuel pump.
  • Like
Reactions: Mtz
