Andy Moore
- Mar 4, 2015
- United Kingdom
Standard firmware with a 64Gb card - camera working great, particularly like Parking Mode although the movement sensor is far too sensitive.
With my camera hard wired to a device where the power can be automatically cut at various voltages (to stop battery being flattened in parking mode), I've had the device set at 12.2V.
This gives me plenty of recording capability but I think 12.2V is a little too low (battery would be at only 50% charge ?). I think I'm going to sacrifice some recording capability in parking mode for a better battery by uping the lowest voltage to 12.4V (75% charge) and turning the movement sensor to 0 from 1 (so effectively I'm using the G Sensor in parking mode). Not sure if a movement sensor setting of 0 will actually turn it off (wopuld have thought so).
Battery should be a bit better with a higher cutoff of 12.4V - would you agree ?
