pietrasnet
I have a dash cam powered by 12v (something similar is fitcamx).
I would like to connect it hard wire to the fuse box, but with the addition battery discharge protection on the camera power cable with the ignition off. Unfortunately, most devices that protects battery have an output voltage of 5V. The Blackvue magic box, on the other hand, has 12v output but has only one output power wire. My camera triggers parking mode on a separate circuit (not via g-sensor) so it need connection to two wires BAT +and ACC.
Do you know of any battery protection device that will work for me (12v output with two power wires)?
Alternatively, I am considering whether Power Magic will work if I connect it to the fuse box with only one BAT+ cable and leave the ACC cable from Power Magic unconnected, while the ACC wire will be connected directly from the camera to the fuse box and BAT+ wire from the camera will be connected to Power Magic. .Of course, I will also connect ground wires
Can it works like this?
