qbacreative
Hi
What is the best battery for Viofo 329S 3ch cams low parking mode?
Alex
Alex
If you have an interest in doing things yourself (DIY), the absolute best option (similar cost, greater capacity, wider temp range) can be found in the thread started by @GPak - the later few pages of posts in the thread are perhaps more useful at this point than the earlier few pages just because the thread spans 2 years of time:What is the best battery for Viofo 329S 3ch cams low parking mode?
Thank you for the useful informationIf you have an interest in doing things yourself (DIY), the absolute best option (similar cost, greater capacity, wider temp range) can be found in the thread started by @GPak - the later few pages of posts in the thread are perhaps more useful at this point than the earlier few pages just because the thread spans 2 years of time:
https://dashcamtalk.com/forum/threads/lto-lithium-titanate-oxide-–-the-ultimate-battery-for-dash-cam-parking-mode-diy.50484/
If you are looking for an off-the-shelf product to purchase as plug-and-play, @Chuck McCoy has done some nice work to review a few of the most available options. Here are some links to get you started:
https://dashcamtalk.com/forum/threads/blackboxmycar-powercell-8-test-review-pp.47956/
https://dashcamtalk.com/forum/threads/viofo-bp100-dash-cam-battery-pack-test-review-pp.58402/
There are many more threads, just poke around a little.
I was planning to stay away from Viofo batteries because it is a new line of product for them that hasn't been tested yet.One reason to lean towards the BP100 is the included Hardwire Output Cable (Type C) (4M) has no voltage cutoffs, so you will get the full benefit of the battery's capacity. You can custom/special order an HK4 or HK6 without voltage cutoff, it's just not readily available on-line. There are some benefits of using the HK6 cable described in this post.
