Chuck McCoy
- Jun 9, 2022
- California
- United States
- 2026 Minimum Spec: STARVIS 2 & HDR & Low Power Parking Mode
Test unit provided by @BlackboxMyCar thank you very much Broseph.
Blah, blah, blah, skip to the bottom for Specifications & Unboxing Video.
This is the 5th Dash Cam Battery Pack I’ve tested.
Oct 2022 BlackboxMyCar PowerCell 8 (EGEN Korea) BBMC PC8 TEST & REVIEW
Dec 2022 BlackVue B-130X (EGEN Korea) BLACKVUE B-130X TEST & REVIEW
Sep 2023 Thinkware BAB-95 (EGEN Korea) not tested
Sep 2024 70mai BL96NNX (70mai China) 70mai BL96NNX TEST & REVIEW
Nov 2025 VIOFO BP100 (Viofo China) VIOFO BP100 TEST & REVIEW
Mar 2026 BlackboxMyCar PowerCell 5 (EnergyWell China)
Jun 2026 Vantrue Power D1 (Vantrue China)
I’ve been following the “global” release of @Energywell Dash Cam Battery Packs since November 2024, and they’re finally available for sale in USA through www.blackboxmycar.com
BBMC PC5 interests me because it does 3 things no other dash cam battery pack currently does;
1.) SMALL SIZE (half size of BBMC PC8, should fit anywhere)
2.) Type-C INPUT CHARGING:
For the first time ever, customers can charge their dash cam battery pack with a laptop / smartphone charger they already own, instead of having to buy yet another "expensive single-use device” like an AC/DC Power Inverter;
https://www.blackboxmycar.com/products/blackboxmycar-power-inverter
The number one question I see from first time dash cam battery pack customers is;
“How do I charge the battery pack if I don’t drive long enough, or often enough?”
EXAMPLE #1: “My commute is only 5 Minutes long”
EXAMPLE #2: “I work from home, I only drive my car once a week”
3.) AUXILIARY CHARGING INPUT:
In addition to traditional hardwire configuration, BBMC PC5 has a second auxiliary HIGH AMPERAGE CHARGING INPUT.
This opens the door for Solar & Power Station Charging.
Location & weather permitting, this means the dash cam battery pack can remain fully charged at 100% during the day, and only begin to discharge when the sun goes down.
This should extend parking mode operation run time.
SPECIFICATIONS:
Official Release Date: December 15, 2025
Official Release Date Amazon US: TBA
MSRP: $200 USD (3/27/26) https://www.blackboxmycar.com/products/blackboxmycar-powercell-5-dash-cam-battery-pack
User Manual: https://cdn.shopify.com/s/files/1/0...Car_-_PowerCell_5_-_Manual_1.pdf?v=1758557058
Capacity: 51.2Wh
Battery Chemistry: LiFePO4
Cell Configuration: 4 Cell
FCC ID: TBA
12V & 24V Support: 12V Only, (does not support 24V heavy duty commercial vehicles)
Charge Time: (33 Minutes) 8 Amp HIGH
Charge Time: (65 Minutes) 4 Amp LOW
Charge Time: (69 Minutes) 45 Watt USB Type-C
Dimensions: 160mm x 87mm x 38mm (6.25” x 3.5” x 1.5”)
Weight: 0.75 kg (1.65 lbs.)
Warranty Period: 1 Year
USA Warranty Shipping Address: US Domestic Address (not China)
Operating Temperature: -10°C - 60°C (14ºF - 140ºF)
Operating Temperature Charging: 0°C - 45°C (32°F - 113°F)
CLA Charge Cable: 12V/10A Male Barrel Connector 5.5mm x 2.1mm
Hardwire Charge Cable: Molex 8-Pin Double Row
USB-A (2) OUTPUT (15W Max) 5V/3A
USB-C (1) INPUT / OUTPUT (45W Max) 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/2.25A
LCD Screen Display: 1.65"
Shutdown Timer: 1-24 Hours
Speaker: Yes (audible beep notifications)
Bluetooth: N/A
Smartphone App: N/A
Firmware Updates: Not Supported
Country of Origin: China
Manufacturer: @Energywell
Unboxing & First Look Video;
Next post should be Q&A
-Chuck
SPECIFICATIONS:
Capacity: 51.2Wh
FCC ID: TBA
Bluetooth: N/A
Smartphone App: N/A
-Chuck
