BlackVue DR500W - Custom firmware + Converting to English / Russian
alexsoll
Retailer
Minsk
Belarus
Street Guardian, BlackVue, Thinkware
July 30, 2014
On forum http://car-dvr.info/forum added:
for BlackVue DR500W-HD
1. Custom firmware (now only Russian)
2. Converting to English / Russian
http://car-dvr.info/forum/index.php?board=68.0
stevenhu
China
I got error 403 (access forbidden) when follow the custom firmware URL.
alexsoll
alexsoll
Retailer
Minsk
Belarus
alexsoll
alexsoll
Retailer
Minsk
Belarus
an update is available
alexsoll
alexsoll
Retailer
Minsk
Belarus
BlackVue DR500W-HD
Raw: https://yadi.sk/i/edz_HB-ydPzFQ
General
Complete name : F:\BlackVue\Record\20141215_225056_N.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 42.5 MiB
Duration : 18s 103ms
Overall bit rate mode : Variable
Overall bit rate : 19.7 Mbps
Encoded date : UTC 2014-12-15 19:51:14
Tagged date : UTC 2014-12-15 19:51:14
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Muxing mode : Container profile=Baseline@0.1
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Source duration : 18s 137ms
Bit rate mode : Variable
Bit rate : 19.6 Mbps
Maximum bit rate : 20.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.057 fps
Minimum frame rate : 14.706 fps
Maximum frame rate : 30.303 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.325
Stream size : 42.3 MiB (100%)
Source stream size : 42.4 MiB (100%)
Language : English
mdhd_Duration : 18103
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 18s 5ms
Bit rate mode : Constant
Bit rate : 24.1 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 8 000 Hz
Compression mode : Lossy
Stream size : 52.9 KiB (0%)
Language : English
