Hello fellow DR550GW users.
Couple of quick issues:
Number 1:
I have been successful in updating the firmware (
DR550GW-2CH_v1.014K(2013.09.25)) , and thanks to the posting above, I was able to get English enable... however, be aware, if you change to another freshly formatted SD card, it will go silent. The new SD card must have the same directory/file setup as the one you modded from or you will likely lose all audio...
Number 2:
I have been unable to get the correct date and time on the device. Initially, I did not get my speed, however that is now working and only the DATE/TIME is set to some system default (2020.08.18). I've monkeyed with the time zone settings, however, no luck.
Any others have this problem? Any suggestions on how to manually set the time/date?
