Sorry for this long log posted bellow but this is what i get when i want to flash one of the elf files i got from givoe. Can anyone see what goes wrong?
Set message level: 3
AMBA_Log_Set_Level.()
[2.2.13.0]
AMBA_Parse_Board_Config:
Board Count = 14, Limit = 40.
AMBA_Parse_Board_Config. (0)
AMBA_USB_Init
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
AMBA_USB_Dev_Init
Found 1 busses, 1 devices changed
AMBA_OS_Get_USB_Location
04DC7B18,0032E934,0032E938)
Filename=\\.\libusb0-0001--0x4255-0x0001
bus=0, port=0
AMBA_OS_Get_USB_Location.(0)
AMBA_USB_Configure
0x04DC7B18,0x0032E93C)
Dev#1: 0x4255 (Amba) : 0x0001 (A4 ) : 123456789ABC has 1 configs
AMBA_USB_Configure.(0x00416F88)
AMBA_Check_State: (0x0032E93C)
State is BOOT
AMBA_Check_State. (0x0)
Found 1 AMBA device!
AMBA_USB_Dev_Init.
AMBA_USB_Init.(1)
ConvertELF(0801-244-2212-20130821-NO1-SPI-1CARD-2710-NOGPS-M8452-NEUTRAL.ELF):
ConvertELF(0).
AMBA_Set_Boot_File: (0x1,0801-244-2212-20130821-NO1-SPI-1CARD-2710-NOGPS-M8452-N
EUTRAL.e2b)
AMBA_Set_Boot_File. ()
Reinit start wait.
AMBA_USB_Download
0,0x1,4)
AMBA_Load_File_BST: (C:\1\bld\a2s.bin,0xc0000000,1)
AMBA_Load_File: (C:\1\bld\a2s.bin,0x00000000,0x0714EE28)
AMBA_Load_File. (0)
Load file start.
Load file end.
AMBA_Load_File_BST. (0)
[0] AMBA_USB_Reinit_Wait: (1,1)
[0] Wait device re-init...
Reinit start signal.
AMBA_USB_Dev_Scan
Found 0 busses, 0 devices changed
04DC7B18,073CF4AC,073CF4B0)
bus=0, port=0
AMBA_USB_Configure
0x04DC7B18,0x073CF4B4)
Dev#1: 0x4255 (AMBA) : 0x0001 (Ambarella USB generic class) : 123456789ABC has 1
configs
AMBA_Check_State: (0x073CF4B4)
State is LOAD
AMBA_Check_State. (0x1)
AMBA_USB_Simple_Command: (0x0,0x8,0x1,0xc00fff00,0x0)
AMBA_USB_Simple_Command. (0)
AMBA_USB_Simple_Response: (0x073CF400,0x00000000)
AMBA_USB_Simple_Response. (0,0x55525350,0x0,0x99005544,0x0,0)
State is LOAD
AMBA_USB_Dev_Scan.
Reinit start wait.
[0] Found.
[0] AMBA_USB_Reinit_Wait. (0)
AMBA_Load_Kernel: (0x5)
AMBA_Load_Kernel_File: (0801-244-2212-20130821-NO1-SPI-1CARD-2710-NOGPS-M8452-NE
UTRAL.e2b,0x0714F09C,0x2,0xc0100000,0x0)
AMBA_Load_File: (0801-244-2212-20130821-NO1-SPI-1CARD-2710-NOGPS-M8452-NEUTRAL.e
2b,0x00000000,0x0714F010)
AMBA_Load_File. (0)
AMBA_USB_Simple_Send: (0x05120020,4723168,0x2,0xc0100000,0x0)
AMBA_USB_Simple_Command: (0x0,0x2,0xc0100000,0x0,0x0)
AMBA_USB_Simple_Response: (0x00000000,0x00000000)
AMBA_USB_Simple_Response. (0,0x55525350,0x0,0x0,0x0,0)
AMBA_USB_Simple_Command: (0x1,0x19d1d629,0x0,0x0,0x0)
AMBA_USB_Simple_Data: (0,0x05120020,4723168)
AMBA_USB_Simple_Data. (0)
Wait for CRC (3000 ms)
AMBA_USB_Simple_Send. (0)
0801-244-2212-20130821-NO1-SPI-1CARD-2710-NOGPS-M8452-NEUTRAL.e2b sent, size=472
3168
AMBA_Load_Kernel_File. (0)
AMBA_USB_Simple_Command: (0x0,0x8,0x1,0xc0100158,0x0)
AMBA_USB_Simple_Response: (0x0714EFB8,0x00000000)
AMBA_USB_Simple_Response. (0,0x55525350,0x0,0xeb000187,0x0,0)
AMBA_USB_Simple_Command: (0x0,0x8,0x1,0xc010015c,0x0)
AMBA_USB_Simple_Response. (0,0x55525350,0x0,0xeb001df0,0x0,0)
AMBA_USB_Simple_Command: (0x0,0x8,0x1,0xc0100160,0x0)
AMBA_USB_Simple_Response. (0,0x55525350,0x0,0xe1200070,0x0,0)
AMBA_Patch_FWPROG: address=0xc0100160
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc0100160,0xe3a04103)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc0100164,0xe12fff14)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0000,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0004,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0008,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a000c,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0010,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0014,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0018,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a001c,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0020,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0024,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a0028,0x0)
AMBA_USB_Simple_Command: (0x0,0x8,0x2,0xc00a002c,0x0)
AMBA_USB_Simple_Command: (0x0,0x15,0x0,0xc0100000,0x0)
Wait firmware programming...
=>Estimation(300000ms)
As far as i can see it goes wrong before or right after flashing the kernel file.
