Module 79L
- May 17, 2015
- Portugal
- AT11DA, SG9665XS, G1W-H
Streaming is more about the connection's upload speed than the amount of data you can use monthly. You can have all those GB to use but you won't be able to stream properly if the upload speed is low, which will probably influence the definition: lower speed, less streamed data, lower resolution.Leave the desicion about resolution and bandwidth to the user. I have a dataplan for 40gb per month on my phone. Also has a 4g modem with 10gb that I can fill up extra if needed.
You can be sure that will be the problem.I don’t mind if 480p is the standard resolution, as long as I have the choise to set it higher.
Problem might be if the camera is to slow to process and stream a higher resolution/bandwidth. :/
By the way, welcome to DCT, mate!
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
