CheckYourLights
- Dec 31, 2012
- Front&Rear-SH800/ Front 2nd Vico-Opia 2
Well since I have tackled getting a camera as low as I can let's go in the other direction.
I decided to toss the lens up on the roof.
First as per my usual I got rid of the 3M dual sided stick. For anyone who cares it was labeled 3M and not some lower end stuff. It also came off very easily. I went dual lock so that I can remove it if need be.
Just in case anyone is curious yes the corresponding piece is now stuck on the roof of my car. It is clear so it doesn't look that bad. I don't mind doing it in the name of DashCam science.
I glued the mount together so that it would not fly off or slide out while I was going down the road.
I ran the cable through my sun roof it seems to fit okay with no issue in the duct of the sunroof with it closed.
I am hoping I can get a hold of another belt clip once is on my C4 and the other is on the C3 my brother has.
It was just run in the sunroof duct for this quick test this afternoon.
Same spot swiveled around.
