When I first got the camera it was too cold out to install the 3-wire and rear camera. So I used the front camera connected via USB for a couple months and it worked perfectly. The other day I finally got the 3-wire and rear camera all connected it up and the camera just isn't working like I'd expect. While driving I have the camera setup to record in 3min loops. I was looking back at my recordings from yesterday and I can see at random times it would switch to 1min loops for a bit and then switch back to 3min. It did this a couple times during the day.
Then in parking mode I have it set to 1fps. I'm assuming this means it would record continuously thru the night until the battery cutoff is reached? However, its recording at random times and was never continuously recording. Sometimes it records for 3 seconds @ 1fps, sometimes it records for slightly longer and then sometimes it records a 1min loop at regular speed.
I'm currently using the stock firmware that shipped with it which is v1.3
