Camera not starting
lolek74
Had the camera for the while and quite happy with it. I had weird thing happened few times.
Started the car and went for a drive. Camera worked perfectly. Parked the car for a few hours. Got back, started the car and drove back home. I noticed only white light on the camera was on and camera wasn't recording. Pulled cigarette lighter out and plugged back it. Camera booted up normally and started recording again.
Since I got camera it probably happened 4-7 times.
I tested the card and it was ok. I tried the second cig lighter and it happened again. I'm not sure what is the root of the problem because it hapens randomly. I'm using SG201500526.002 firmware .
There is a known problem with the May/July firmware, we actually asked everyone to roll back to the release version (March). We have several new builds of a new October beta firmware we are testing this week, latest build was released a few hours ago actually. @jokiin will take care of you soon since you're in Australia.
Your version should show March not May
SG201500526.002 = May 26th 2015
That should be the March release version posted here:
https://dashcamtalk.com/forum/threads/sg9665gc-firmware-update.11806/
"If for whatever reason you want to rollback to the previous version firmware it can be downloaded from here
http://www.mediafire.com/download/l39ilbglznqisaw/SG9665GC_Firmware_release_version.rar"
Rick will most likely have you try the new October firmware soon I'm sure. (new SDK build, optimizes several things)
can you roll back to the March version and let me know how you go, I'll be back in Australia tomorrow and can follow up with you again then
Can't view your link right now but will check it when I get back tomorrow, may send you an updated firmware also with some file handling changes that we're testing right now
It might take few moments to update the file. I reformatted the card in the PC then formated again in the cam and it works again.
No problem. I'll hang till then.
Quick update.
Formated the card and cam works again. I will have to wait until the card fills up again and see if there is any issue. I'm using Genuine 64GB Kingston card.
Any chance I could use new FW as it supposed to have a better file handling.🙄
if using a 64gb card must always remember to format in the camera, will be putting out an update soon with support for more 64gb cards as well
What does the camera do when formatting that's different to a computer ?
computer will format a 64gb card exFAT, the camera will format it FAT32, you can do it in computer but you need to use a 3rd party program to format the card FAT32
