Cannot get endcap off 0806 to refocus
TommyJ
I see Mtz posting on removing end cap. Put fingernail in between cap and body and then rotate ring upwards. Is there something to press inside the joint? or how far to twist? Cannot figure whether to try to POP it of by wedging a screwdriver in the joint.
Anyone with recent experience or a video for this one?
No, I am still not able to get the Outside end cap off. Haven''t gotten in to see the screws yet.
rotate the ring so the base contacts line up with the lens..
the internal fixing lugs are at the top and bottom of the camera..
it practically drops off in this position... but at least, ... you should see a slight gap open that a fingernail can pop off.
"Rotate the ring so the base contacts line up with the lens..
it practically drops off in this position... but at least, ... you should see a slight gap open that a fingernail can pop off."
Mount lined up with Lens--check
Thumbnail into crack at bottom--check
! No sign of any give at all!
That is decidedly odd !
Nope...... Not gotten to see the screws yet. I still have not been able to remove the end cover. It won't POP off!
Thanks for your attention to my dilemma. I have decided that I will defer trying to refocus the 0806 for now, and go ahead and mount it in my car and enjoy using it for now. Later will come back to this problem of refocusing.
I have found the dashcam forum interesting and it was great dashcam primer.
Thanks again,
I had major problems with getting the top off as well. Maybe they made the clips a bit stronger / wider than before. Anyway, after spending a lot of time getting nowhere wrecking my thumb and thumbnail, got the small / thin screw driver out. Just got it in (in-line with the main body join) and lifted the end cap up at that point. Certainly not easy for me with just my thumb. I was thinking of doing a disassembly video when I got time for anyone else in the same boat.
Well......... Yesterday I looked over at the dashcam and thought I would try once more. With my sore thumb, I go the slit open an put a screwdriver into it . Then I proceeded to crack the main body of the dashcam!
I saw your note today and thought I would try once more but on the opposite side from my crack. IT CAME OFF! What a pain in the neck. Now on to my refocus attempt
Thanks for the encouragement.
