Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
I don't know what voltages you were using? How much power did you put in/get back out, measured in Wh?the Cellink Neo6 took around 45mins(9A mode) to fully charge from 0% to 100% as I purposely drain the Cellink battery down to 0% until the output cut off(using 2A load which is the max output of the Cellink) & recharge back using home power supply. 2A load on output took around 3hrs to drain the battery from 100% to 0%. The charging current is very constant which at 9A until reach 100% then current slowly drop off within 2mins to 0A.
