So I could take the original cigarette lighter power lead that came with the camera and cut off the end that goes into the power socket (I think there is also a little black box in the cable....leave that in place), then split the two cables (pos and neg) and use a tap a fuse in the same way as the hardwire kit....effectively turning the cigarette lighter cable into a hardwire kit? I'm working with Nikolai on something and one option I was considering was adding a 2nd cigarette lighter socket by the fusebox and then plugging the original cable into that. Whilst cutting the end off means its no longer "portable" (which isn't a problem as I hide the wires anyway, making it not easy to remove) it would make it a neater solution than adding an extra socket...a bit cheaper and obviously 1 less link in the chain! Could I do it this way?
