I have had a DR900S-2ch installed by a local shop, hard wired using the Power Magic Pro.
I am confused about Parking mode and I am doubting whether the dashcam has been wired properly, so bear with me with a few questions:
1. With the Power Magic Pro Switch to the ON position and the setting the on DashCam set as Parking Mode as OFF, should the camera be recording continuously? ( i.e the camera is PERMANENTLY ON recording footage to the card until the voltage drops to cut power to the camera)
- mine is recording continuously
2. If I set the Power Magic Pro Switch to the OFF position and in camera Parking Mode setting ON, how long would it take before the DashCam shuts down after the engine is switched OFF and should it go into Parking mode?
- mine goes into Parking mode is switching off after several minutes I think because the battery voltage is low
(I suspect the battery charge is low as I keep getting messages about the power steering having reduced power - this is what happened after I had just bought the car and was fixed when the battery was topped up)
I have a a feeling the DashCam has not been hardwired properly
