kevindd992002
- Nov 16, 2018
- Metro Manila
- Philippines
- A129 Duo
I forgot to add that I already have the HK3 installed and up and running. But I'm confused with some parking modes.I’m not aware of anyone needing boot delay for non diesel engines. I’m sure it’s technically possible for someone. You only need it if you have trouble with the camera turning on every time then you would enable some
I don’t see a good reason to use motion detection or time lapse during normal 2-wire cig power while driving.
Get the special A129 3-wire hard wire kit if you want to utilize parking mode settings.
If motion detection is turned off, will auto event detection work?
Which parking mode will the G-sensor work for? In normal mode, I know this is used to automaticalky lock the video.
Sent from my SM-G950F using Tapatalk
