Wolfie
- Jun 1, 2016
https://dashcamtalk.com/forum/threads/new-to-this-site-been-looking-at-dashcams.19445/
Still happy with the DAB205 that I got from @CaptureYourAction, but thinking about either getting a new dual camera system, or a second cam to use.
There is the possibility that I will try doing the Uber/Lyft thing, and if I do, I'll want a cam that I can face towards the backseat as a form of protection, not only against false claims, but in case I need proof of anything having happened. So either a new cam to face the back, or the DAB205 reallocated (turned around) to facing the back, or a new dual-cam system that can handle both front and back at the same time. I know that most (or all?) dual cam units are actually two separate pieces, my hope is that there is one that is designed to be used inside the car (either instead of outside only).
The vehicle I have is a 2004 GMC Envoy XL, and the 'cigarette' outlets are always on/hot/whatever. Because of this, I'm also investigating ways to either add a switch to one or more of the outlets, or something (like on Amazon) that would plug into an outlet and have a power button attached. Any ideas on this matter would also be appreciated. I've found some on Amazon, where they are either a single unit, or a piece that plugs in with a cable going to the main unit, most have USB chargers as part of unit, which isn't a bad thing. Overall goal here is to somewhat modernize the vehicle without cluttering it up too much with cables and things to plug in.
Another issue to mention, in case someone knows of a remedy, especially in conjunction with the aforementioned outlets, the current adapter I use for the DAB205 (which came with the camera) has trouble making a connection in the outlets, which I blame on the outlets instead of the plug (I believe if the outlets were newer, there wouldn't be an issue). On the flip side, little adapters to generate powered USB powers seem work just fine, except when the dashcam is running and I turn on the vehicle, then it seems to cause issues with the cam, so not sure if the current adapter has some sort of surge/power loss protection, or if the little adapters are just crap quality that are causing the issue. If anyone else has the DAB205 but is using an alternative power (ie, USB ports and not the included car adapter), please let me know.
Of course, I'm thankful for any help that can be given. I'm hoping that CYA will have some information for me in regards to the cams, but I welcome feedback from others, especially those who may be doing the Uber/Lyft thing with what cams to consider (or to avoid).
Also, a big TY to DCT. It led me to a great purchase, and is the only place that comes to mind when I want to look into dashcams.
