HombrƩ
- Jan 16, 2015
- North East NSW
- Australia
- VIOFO A119 PRO VIOFO A119S - V2
Have you fully checked/tested the card with the programs suggested here first
As per my experience this is a power related issue. Switching to the included cable took care of the corruption issue.
Its amazing how cheap aftermarket gear can cause so many issues
Have you tried this yet?I picked up a VIOFO A119S in the Spring and have noticed an ongoing problem with corrupted files.
The first few files will be fine, proper length (~400-500MB) but then remaining files are 5-10MB and are corrupted. This is using a Transcend High Endurance 32GB micro SD Card.
I thought upgrading the firmware might help (upgraded it, reset all the options and formatted the sd card after) and no luck. I still get mostly corrupted files.
Any thoughts?
The power draw seems higher, which generic cables aren't able to support...
I agree, but somewhere specs were given and by the numbers (which I don't remember exactly) they seemed normal- always less than 500mA. Yet every evidence points to this cam requiring more than usual amount of current š± Power it well and then it's reliable š
I also would have suspected a power problem, because most of your short files reported here have the sequence number ...001.mp4 which normally is applied to the first file after a power-up. This could indicate power cycling which can occur in as little as 15 seconds or so between cycles and usually corrupts the file. Power cycling should cause the startup sound and the momentary VIOFO Logo display each time the camera powers up. Disappointed original cable and 12 to 5Vdc converter didn't help. To separate camera problems from car power wiring problems, you might try powering the camera at home with the supplied short cable and a USB +5Vdc wall charger or USB 5Vdc power bank (a computer won't work, you get the mass storage screen). Power the camera using the side input connection, not the GPS mount input. I've used and abused Transcend High Endurance 32 and 64GByte cards for a year or so and they have worked fine for me. By the way, corrupt files may be restored frequently by playing back the file in the camera.Went for about 4 weeks (formatted card before starting) with the original/included USB cable and USB power adapter. Same problem: corrupted files.
I'm pretty much tired of fooling with it after 6 months.
If you want to test more before spending money, you could check the cig socket adapter function in the car using the supplied short cable with the A119 dismounted from the windshield. If you see heavy flickering on the A119 LCD screen or the A119 turning itself on and off (power cycling), that's a sign of insufficient power getting to the A119. I've read that the Viofo supplied cig socket adapter doesn't connect well to some car cig adapter sockets, so you might check that. You could check camera function indoors using the long cable (in place of the short cable) indoors with a wall charger to verify your supplied long cable is good. Gently flex the cable near the ends to look for intermittent problems. Worst of all it could be the combined affect of both components being marginal or exhibiting an intermittent problem.I let it run for a day, plugged into a USB port (charging) at home and it looks like there was no corruption. That suggests that it's a power issue. I'll swap the cables in the car and maybe try to find a USB charger capable of 3.1A.
