Nissanboard
- Mar 11, 2013
- Germany
Today I got my CR 500 HD, currently there is Firmeware 1.00.112 installed and 1.00.115 is the newest.
So I want to update the firmeware with this instructions:
http://dashcamtalk.com/finevu-cr-500hd/
Is it also possible to format the card and to upload the Firmeware while USB is connected ?
Because I dont have a card reader on my notebook.
Firmware Update Instructions
1 Download the latest firmware.
2 Remove the Micro SD card from the dash cam and place it in the micro SD adapter. Insert into a memory card reader on a PC.
3 It is recommended that you back up all important files on the Micro SD card.
4 Format the memory card prior to the firmware upgrade
5 Unzip the downloaded firmware and copy it to the root directory of the memory card.
6 When you insert the micro SD card into the black box and turn the power on, 4 LEDs will flash and the upgrade will start.
7 The upgrade takes approximately 3 minutes. When the upgrade is complete, the firmware file will automatically be deleted.
