It's failed to capture the previous two instances of vandalism, due to being powered down.Why not use the A139?
Unless they are stealing the camera then it will capture the culprits just as well, and probably better, low bitrate parking mode never misses anything, as long as it has power.
Using LTE is going to empty the battery even faster.Considering Thinkware U3000 or Blackvue DR970X LTE.
Yes, disconnect one and you get around 20% extra recording time.I guess part of the issue is having 3 channels running at once.
It would probably shorten the recording time, since the camera will get its power from the battery pack, and will stop when the battery pack is empty, they don't switch over to the car battery.Is there perhaps some way to add a battery pack to extend the parking mode running length?
Hey Nigel, Can all viofo and dashcams be powered with normal power banks?Using LTE is going to empty the battery even faster.
The U3000 does have a high efficiency radar parking mode which will provide coverage for a lot longer, but it may also miss the important video through being asleep and the LTE will be disabled when using the radar.
How much time do you drive every day?
If you don't drive enough then the car battery, or battery pack will not charge to full, so you will get limited recording time. I would expect a 096 AGM battery to do quite well for a normal commute time, but it wont charge to full in 10 minutes.
A possibility is to use a standard USB powerbank and charge it fully indoors every day, then plug the A139 into that overnight, a 20,000 mAh USB powerbank should power the the A139 with 3 channels for, I think it is about 14 hours, and you can get bigger ones than that.
I found my car with two flat tyres. I have ring doorbell footage showing a neighbour going past my front door, two loud pop noises, then walking back. The car is unfortunately not in view of the doorbell camera. The Police said because it does not show them actually bending down and causing the damage, a court couldn't consider that to be evidence against them and they would not even bother speaking to them.CUZ i am going to have to be judge & jury CUZ the law here is broken.
I decided to go for the u3000 for the radar feature's claimed ability to record for longer periods. Some people report issues with rear radar detection, while some don't. I am yet to fully test.U3000s radar parking mode does not work as they market. Check this forum for the complaints others have posted.
It highlights its consistent capture capability, ensuring the recording of any activity and potentially aiding in identifying culprits, suggesting its effectiveness in continuous monitoring, provided there's a power source for uninterrupted operation.Unless they are stealing the camera then it will capture the culprits just as well, and probably better, low bitrate parking mode never misses anything, as long as it has power.
