Custom firmware Procam CX4 revision 3.0
Sila, Where can we download Procam_CX4_v3_fw_20140728_Constant_Bitrate_36Mbit_Contrast_34-40-30_Sharpness_04-05-03_Expo_Texet.bin?
I assumed he took the one already posted and used A7 tool to crank up the bit rate, but I could be mistaken.
Hi friends
We present you the new firmware from ProCam fw_20140919 (fixed the problem with mute controls), modified and improved Russian users with of the forum taker.im: Kaliningrad7, Samohod1, discograff ...
Edit: constant bitrate 18-20-24, contrast, sharpness, expo tables, are certain menus.
Menu "quality": 24 Mbit / s, 20 Mbit / s, 18 Mbit / s
Menu "Expo Mode": mod Texet 5 GP, Texet 5 GP
boot_logo and shutdown_logo
Metering table from Texet 5 GP and modified Texet 5 GP:
Table №1 Expo modified Texet 5 GP
010100000000000000000101
010101000000000000010101
010101010000000001010101
010202020202020202020201
010202020304040302020201
010202030405050403020201
Table №2 Expo Texet 5 GP
010102020304040302020101
Square - the matrix.
Digits - sensitivity.
0 - matrix does not react to light
Above the value of the digit 1 - above reaction.
https://yadi.sk/d/6CRWWvUJcrBGg
MD5: 16e0c5850acdd8b6d48e40632ac98ec6
The firmware is tested and fully functional.
Nevertheless, all that you do, you do at your own risk.
Good luck
I have tested today the rom,
Auto power off is not working, Cam remains recording till battery is empty.
Than i selected 24 Mbit, the files are recording them at 20Mbit, selecting 20Mbit it records on 10 MBit.
18 Mbit setting result in files with a bit rate of 8Mbit.
Some work to do :)
Autodelta,
You have done a reset after flashing?
The problems that you described, they are not ))
After reset Auto power of is working fine.
Data rates remain the same but that is no problem, 20 Mbit is fine,
Higher bitrate makes large mov files.
I am glad that you have succeeded.
Reset must be done after each firmware
In addition, the large file size, this is normal.
This and is conceived:
