Dan Robinson
Yes all failures happened while cameras were still mounted. The vertical clearance needed to remove the entire camera from the mount with the plug still in is more than the room needed to remove the plug by itself.
were you using the thin mounts?Plug after separation:
Socket:
PCB socket separation view from disassembled camera:
can see the ones they are done by feel as there are generally scratches all around the portsOnly tried that once, long ago with a 'GC' V1. Much easier to 'dismount' the camera first. If nothing else makes it a lot easier to see the various sockets rather than trying to do it 'by feel'.
What could cause that type of damage from roughly 2 dozen unplug cycles over 4 years?
After spending over $1000 on this dashcam setup (four original SGs then a V3 after the first pcb failure). I can assure everyone that I don't unplug them by yanking the wires.
So, if I were to use probes to test the two non powering units, which contacts are positive and negative in the socket? I guess I could find out by ripping apart a plug.
I have seen the cables break like that before, have replaced probably about a dozen in the last two years, generally when it has happened they've been forced (not saying that is the case here) from people trying to plug unplug while the camera is mounted, in each case though we've just replaced the power lead and asked the customer to remove the camera before plugging/unplugging and that has been the end of it, had we been contacted and known about these we'd have replaced the leads, opening things up and repairing is not something most people could/should be doingUnless excessive heat or a chemical-laden atmosphere has softened up plastic somewhere along the way I can't see how this could have happened but it's clear that it did happen so I'm lost at this point.
correct@jokiin Thank you! Looking at the socket with the wider part on top, 1 is on the left and 5 on the right, correct?
I will say that with Dan doing pro-level storm photography, I'm certain he doesn't abuse the equipment he's making money with. In a similar vein I'm just as certain that Jokiin wouldn't use a known inferior socket or plug with his cams.
no, but lets see how @Dan Robinson goes with it and if he's stuck we'll see what we can do to help him outWondering aloud if Jon has the facilities to install new sockets?
