AAAdenyClaimOnPurpose
- Aug 26, 2018
I have been using the A129 and I am happy with the performance.
which sd card did you purchase?
I’ve been using an A129 for several weeks and just added another one for the wife’s car. No complaints on either one. For me they’ve been rock solid. I won’t lie, parking mode needs some work, but there is development coming and I have no doubt they’ll get it right. So far I’m very impressed.
has the major problems such as freezing and forgetting settings been fixed?
I purchased a couple of the Samsung EVO Select 256gb from Amazon and they work with no problem. use them on my GoPro also with no problemswhich sd card did you purchase?
U1 is plenty fast enough. In some cameras they work better than the U3 cards but the A129 seems to work with both speeds. There are plenty of people using the Evo U3 with the A129, including me, without problems. I would go for the card with more memory so that the loop recording retains the video for longer, might come in useful some day. Unless you are recording at full speed 24 hours per day then the endurance is not going to be of much benefit for several years, by which time it may be outdated and too small to be of much use.I'm debating if I should get the evo select with U3 or the high endurance card. I have personal doubts on both because a) I've read on the reveal that by using the evo select, someone's 128 card went into read only mode. the evo select with U3 is definitely fast enough for dual camera, but if I were to go with the high endurance card, I'm not sure if it's fast enough being that it's U1. Is a class 10 card fast enough for dual camera at 1080p 30 fps ..does anyone know? Do you use your GoPro a LOT?
Samsung Evo Select 128G. So far no issues. If I do have issues in the future, I'll switch to a Samsung Endurance most likely. But for less money I just had to give the Select a try.which sd card did you purchase?
I don't think Viofo "make microSDXC cards" itself, but you always can get Transcend 128gb MLC from Amazon or get a 256gb cheaper one, it might even work, not sure for how many hours.but still, the Samsung EVO works fine for much less then the MLC type so why pay the extra money? plus viofo only make 64gb.max. they should make high capacity 128's and 256's for the A129 two channel for longer time between over-writings.. stilll the Samsung EVO select 256 in my GoPro has lasted 3 years so far in heat water on the hot race tracks etc and it works fine no reason for MLC. its an over kill its like driving with an extra few dash cams ..its good but its overkill.
D | Newbie question: What Does the a 129 c0nnect to for power? | A129 / 129 Duo | 14 | |
K | Does the G sensor launch firmware in parking mode? | A129 / 129 Duo | 1 | |
Does CPL filter really work? | A129 / 129 Duo | 19 | ||
When does Camera turn on? | A129 / 129 Duo | 35 | ||
Does Viofo g-Sensor Work With Low Bitrate Parking Mode? | A129 / 129 Duo | 15 |
