SNIPE
- Apr 20, 2021
- Belfast
- United Kingdom
- BLACKVUE 900X 2 CHANNEL
Hello folks I just purchased the Cellink NEO 9 Dash Cam Battery backup to use with my Black Vue 900X camera.
Problem is do I use a constant 12V power supply from the cars fuse box and then connect the green cable from the cellink 12V into the switched 12V on the cars fuse box, I take it doing it that way the cellink will only receive power when the car engine is running and not keep charging the Cellink when the car is switched off as I have got not one clue can anyone confirm if this is correct or have I got it totally wrong as I assumed I would connect only to the 12V switched on the cars fuse box but now this new information has me baffled.
It is hard to get information on this as I have read a few posts and I seem to get conflicting information. Finally I take it I only use the ground and yellow wires to the blackvue via 12V female cigarette adapter then connect the blackvue male cigarette connector into 12V female...
Thank you to all who reply, thank you for your help.
