Onetenner
- Oct 26, 2025
- Ubique
- United Kingdom
- Vueroid D40-Q2
Firstly, this isn't a 'review' as such, just my opinions & observations.
This 'story' started when I had need to check some recordings from my Thinkware Q850, which I'd been happy with since I fitted it just over a year ago. The problem was the registration plates were unreadable in parking mode, at night - in a well-lit street....
That led me to purchase a Thinkware U3000 Pro - for me, too invasive and the wrong form factor which led to about 30% of the image being obscured. Next, Thinkware ARC 900, currently unavailable in UK so imported from Canada, it's a 'better' fit but the images are not as good as I think they could, or maybe should be for the money.
Having looked at pre-release reviews & images, I've now installed an Elite 9, initial images are good but so far, conditions have been optimal - I'm looking for 'edge case' improvements. Time will tell.
Installation was straightforward-ish, the power connector is the same type as used by Thinkware, so happy days, just plug it in eh? No. It's wired differently.... It'd probably be electrically protected from polarity reversal (I'd hope it would!) but I'm glad my 'never assume, always check' mindset kicked in.
Unlike the ARC 900, the Elite 9 has live view, which makes positioning and alignment so much easier, the ARC 900 has a small screen but it's no use when you're trying to position a rear camera in a big car.
Connection to the camera through the phone application was straightforward - although I did have a ??? moment, I'd scanned the QR code in the box to set up the application prior to installation, then when I opened the app once the camera was connected to power, on trying to add the camera (which seems the obvious thing to do) I got an 'already registered' error message.
Overall, I have to say that the software and pairing process is more 'Apple' than 'Android' - it just works, no faffing around turning off auto-join for nearby saved networks, and no having to scan a QR code every time you want to connect to the camera, unlike the ARC 900.
One feature I do like is the ability to deselect areas of the image for park recording, I'd seen no mention of it - maybe it's a standard Blackvue feature?
It's early days yet - and I'll be hot-swapping the two cameras around over the next couple of weeks (I don't want to have both on the screen at the same time, I'd find it to visually distracting!)
Talking of hot, I have noticed there is a noticeable amount of heat generated by the Elite 9, something I'd not noticed from any of the Thinkware models - they just about generated enough to keep the screen clear around the lens, this feels like it'll keep the ice off the pan. roof too! Of course, it takes electrical energy to generate heat so I'll be keeping an eye on the state of battery charge, I noted this once the camera had been in park mode for just over an hour.
A couple of screenshots from a drive out earlier.
I've got a couple of CPL filters en-route, so hopefully that'll sort out the reflections, I can already see some improvement in daytime registration plate readability, as mentioned, for me, it's night-time static and dynamic readability that I want to gain. I'm not expecting ANPR class results and I don't want to go down the Chinese brand route although admittedly they do seem to have the edge...
