hi friend, i have m500 chinese version. i want to change the voiceover to english.How to disable power-up sound
Hello, my dashcam has just been delivered to me and I noticed that the power-up sound doesn't rely on the speaker volume settings. Is there ANY way of getting rid of it? It's so annoying that I'm even willing to disconnect the speaker in device's hardware, if needed. Thank you for any advice!dashcamtalk.com
yes, turn out my m500 inetd was 481. finally successfully change the voice over to english.try kill 418 or use "ps" and look for inetd and the number is the number they do have to kill
I found this thread https://dashcamtalk.com/forum/threa...-m300-international-version.46304/post-581288 , may be some use for you.Hello guys!
Any updates on flashing M500 cam to international/english version?
Replacing the voiceover is kinda halfway solution...
Would be nice to be able to use local app version and use voice commands in English
tho, @papagena139, could you describe more precisely how you generated own voice by AI?
Yes, you can do it. There are two firmware versions on the link, for the international version and the Chinese one. You need to install the latest firmware (1.2.19 ww). If the device behaves strangely, will not be able to connect to the "70mai" application from the market, then install the Chinese firmware back and require a replacement from your seller.
M500_FW - Google Drive
drive.google.com
Did you used another and especially shorter USB cable?You mean which one? You can try to follow the directions provided here
to apply the firmware I found here
...but it did not work for me, as in I have no idea how to trigger the update process. The dashcam does not appear as a USB drive no matter what cable I use.
