Oilburner
- Apr 23, 2017
- United Kingdom
- Trancend Drive Pro 220 & Thinkware F770 Dual
Whilst on holiday my recently installed F770 & Cellink stopped working suddenly after a 4 1/2 hour trip, the vehicle had only done a couple of short 1 hour trips prior to this longer trip, and it worked perfectly whilst driving and using the park feature I even removed the cellink battery to check its state of charge using a dedicated 12 volt 10amp charger, after being connected for less than 7-10minutes the cellink displayed battery full, so it was obviously being charged by the vehicle successfully this was all carried prior to a longer trip.
The vehicle had just done a 200 mile trip the day before working pefectly, next day about a 80 mile trip still working good it then was parked and set for parking mode operation which was for three hours exactly, on return I noticied the F770 had turned itself off, I first thought had the F770 got hot whilst parked and switched itself off automatically to protect itself, athough the outside temp was only 16-17 C, I did not think that was the problem, I checked the cellink this was cold to touch as its stored in the rear cargo area under floor panel not affected by heat during parking.
I first thought this may be a internal fault on the F770 because for a split second it started then immediatly turn off, so the following six days it did not work whilst on holiday, however once at home I checked all of the installation wiring including the inline fuses with my multimeter, everything checked out ok, I then unplugged the Cellink battery and checked with the multimeter on the input side of the cellink battery plug as this was the easiest to check, but did not get any voltage showing on the multimeter, now whilst this is the input lead I would have expected to get a reading, I then took the cellink indoors to connect to my dedicated 12 volt 10 amp charger/supply and I was surprised it took just over 1 1/4 hrs to state full, on reconnecting the cellink back to the vehicle surprisingly the F770 started working again, now this is not what I was expecting so is this a faulty cellink battery or what ! or could the problem still lie with the F770
pulling the voltage down due to a internal fault.
