Just bought a Blackvue DR650GW-2CH and a Cellink B Battery. So far so good, just wanted to know:
When the SD card is full and I want to get more space again, can I copy all the files I want to keep from the "record" folder to my PC then simply delete everything in the folder or does it have to be done in the Blackvue viewer because the viewer only lets you export or delete one file at a time.
Whenever you format the SD card, do you have to reapply the same settings each time, for example the location/sensitivity?
Regarding the Cellink, for anyone that owns one. Basically I have it connected to the 12v cigar jack and set to 5A on the side of the battery. Can I leave it on this setting for good or should it be turned to off when not being used? I disconnect my dash cam from the battery overnight when the car is parked in the garage.
When is the new firmware due that will support the 8mpbs front and 3 mpbs rear quality again like the original firmware did?
Any feedback would be appreciated.
