susobarral
- Feb 17, 2013
- Lugo
- Spain
- Git2,Xiaomi Yi, Mobius, Sj1000, gt300w, GS9000, GS600, Gopro
FIREFLY 6S
Look Very good
from Bangood
127.79 dólares
Brand Name: Hawkeye
Item Name: Firefly 6S camera
Photo Resolution: 16M/8M/5M,
Video Resolution: 4K@24fps(Quicktime player required);2.5K@30fps,1080P@60fps,720P@120fps;VGA@30fps
ISO: AUTO/100/1600
AV Output Format : PAL/ NTSC
USB Port: compatible with Gopro Gimbals
Support HDMI output:YES
Support max 64G TF card, Class 10
Support WiFi
Specification:
Size: 59 x 41 x 12mm
Weight: 70g
Battery Capacity: 1600mAh (can be detached, compatible with Gopro3/3+ battery)
Working Voltage: 5V
Working + Charging Current: 800mA
Working Time:1.5h
Charging Time: 2-3h
Compressed Format : H264
Video/ Photo Format: *.MOV / *.JPG
Color:Black/Golden/Silver White
Optical Parameter:
Diaphragm: F/2.8,7 glasses
Angle: 120 degree level, 170 degree diagonal
Mode:
Video;Photo;Time-lapse video;Time-lapse photo;11 Burst Photo
Buttons:
Power Button: Press once for power on, long press 3 sec. to turn off, Photo/ Record Mode switch.
OK Button: Start/ Stop recording
Up Button: Enter menu/ Add options of menu; long press to turn on WiFi
Down Button: Enter menu/ reduce options of menu.
Contrast FIREFLY 6s with FIREFLY 5sOnly the difference)
FIREFLY 6s FIREFLY 5s
Photo resolution 16M(suggested)
8M
5M 12M(suggested)
8M
5M
Video resolution 4K@24fps
2.5K@30fps,
1080P@60fps,
720P@120fps;
VGA@30fps 1280P@30fps;
720p@60fps,etc
Light frequency setting
50HZ/60HZ
(When usd in indoor, you can use this setting to avoid light.) NO
Remove fisheye Turn ON to reduce Fish eye effect NO
Gyro image stabilization Yes(Video Test) NO
Angle adjustment
2 options: Large / Medium . Small angle can reduce image distortion.
(Large angle is suggested as using smaller angle will reduce image quality.)
3 options: Large / Medium / Small.
Time-lapse video to start/stop time-lapse video at 0.5 / 1 / 3 / 5 /10second intervals.
to start/stop time-lapse video at 0.5 or 3 second
intervals.
Sport accessories Yes NO
Cycle recording
(This mode is suggested to be used in vehicle monitoring.)
If cycle recording mode is selected, the video will be cut
into 5-minute segments. The earliest files will be covered when the TF
card is full.
card is full.
USB Power Up Auto-record
(This mode is suggested to be used in vehicle monitoring or aerial
photographing.)
If this function on, it will automatically start
recording when connected to external power source via USB.
WDR (Wide Dynamic Range)
(This mode is not suggested to be used in sunny days).
WDR function is suggested to be used in
cloudy/dark environment. It might cause overexposure in sunny days.
Burst photo capture 11 photos in 1 second. capture 11 photos in 1 second.
ISO adjustment AUTO/100/400/1600 AUTO/100/400/1600
Sharpness adjustment 3 options: High, Medium and Low. 3 options: High, Medium and Low.
Color adjustment 2 options: standard and vivid. 2 options: standard and vivid.
Time stamping
this option allows you to stamp the time on the photos or
videos.
videos.
TV output mode PAL / NTSC PAL / NTSC
Wi-Fi remote Yes Yes
USB Auto power-off
the power will be automatically turned off in 30
seconds after the USB power supply is cut.
Feature:
-Small, Light, 16MP HD camera
-With WiFi function, can download the APP "FIREFLY" or scan the two-dimension code above , to transmit the live image to your phone.
-Compatible with GoPro Camera accessories, includes batteries, gimbals and USB device etc.
-More convenience for FPV system.
-50HZ/60HZ light freqquency setting:When used in indoor, it can avoid the flashing lights.
-Trun ON to reduce Fish eye effect.
-Gyro Image stabilization
Package Included:
1 x FIREFLY 6S 4K WiFi Sport HD DV Camera
1 x Waterproof Case
1 x 1600mAh Battery
1 x Lens Cover
1 x USB cable
1 x Sport accessories
1 x Manual
NoteVery Important)
-AV cable not include
-Please download to update the camera: Newest firmware
1.Format the card(FAT32)
2.Put the firmware into the card root directory
3.Restart and the camera will be automatically updated.(update process with LED flashes)
4.It will automatically boot after the update is complete.
5.Please remeber delete the firmware after completing update.
Look Very good
from Bangood
127.79 dólares
Brand Name: Hawkeye
ISO: AUTO/100/1600
Support WiFi
Specification:
Weight: 70g
Working Voltage: 5V
Working Time:1.5h
Charging Time: 2-3h
Optical Parameter:
Mode:
Buttons:
8M
5M 12M(suggested)
8M
5M
2.5K@30fps,
1080P@60fps,
720P@120fps;
720p@60fps,etc
50HZ/60HZ
Angle adjustment
intervals.
Cycle recording
card is full.
card is full.
photographing.)
Time stamping
videos.
videos.
USB Auto power-off
Feature:
Package Included:
1 x Waterproof Case
1 x 1600mAh Battery
1 x Lens Cover
1 x USB cable
1 x Manual
NoteVery Important)
