Paul Iddon
- Apr 5, 2016
- Preston
- United Kingdom
- Viofo A139 Pro 4K, A129 Pro Duo 4K, A229 Duo 2K, & NB 522GW
The Adelphi has some nasty lighting, but otherwise pretty good 🙂Set to 60hz to get 30fps.
That's where the Americans come in, and perhaps southern Europe. The UK doesn't get enough heat in their summertime for proper testing.The Adelphi has some nasty lighting, but otherwise pretty good 🙂
Proof that the 50/60Hz setting should be scrapped, just like the analogue PAL TV that it comes from has been scrapped for decades!
There is a traffic light with zero light @0:11, very unusual, but I doubt that was a result of using 60Hz.
Perfect time of year for testing that dashcams don't overheat in the sunshine, but maybe not in Britain!
Same here, I've let them know that a while back for the previous 4K Omni. Makes it far more discreet to be black like most other manufacturersOne thing to mention, and this goes for all makes of dashcam, is the 3M sticky pads are iften grey - this doesn't help to conceal them much at all, it would be far better I think if the pads were black which would make them less obvious to spot on through the windscreen.
Same over here, the very same systems seemed to come from your direction.It was hissing down with rain!
Agreed.One thing to mention, and this goes for all makes of dashcam, is the 3M sticky pads are iften grey - this doesn't help to conceal them much at all, it would be far better I think if the pads were black which would make them less obvious to spot on through the windscreen.
