D
Deleted member 85644
Guest
The A229 Plus/Pro can only support FAT32. If you insert a card with the format in exFat, there will be a card error shown on the camera and ask you to format the card. You need to press OK to format it first, and then you can use the camera normally. According to the screenshot, you have opened the files from the card, so you cannot format it with the tool successfully. Please close the files you opened from the card first, and then try to format it again.
@VIOFO-Support - the manual says otherwise, so the manual should be corrected. Page 9 of the on-line and paper manual.
I have not tried the two exFAT formatted cards yet, but based on what you have stated, I will not expect them to work.
