I have a G90 SVN r429M version is 25fps 1080 and 50fps 720, but I wanted it to 30fps and 60fps with fimware SVN 293.Is the D90 definitely the a7la30 version then?
realy sure OMGHave you tried changing the TV Mode from PAL to NTSC as that should then give you the 30fps options 🙂
Yeah it's a quirk of the Ambarella cams - if you set them to PAL they'll record in 25fps whereas in NTSC they'll do 30fps and the menu items will change accordingly 🙂
THANKS THANKS THANKSYeah it's a quirk of the Ambarella cams - if you set them to PAL they'll record in 25fps whereas in NTSC they'll do 30fps and the menu items will change accordingly 🙂
Are you quite sure it is for charging?Does anyone know if this will work powered from the built in USB port in my glove box of my vehicle?
Then i think it will work, if i remember correctly iphone charging port was rated for more than 2 amperes, so it's more than adequate.The usb in my glove box plays music and charges my iPhone.
