Gary D
On the GC, assuming that "loop recording" is set to the default 3 minutes... and it's automatically recording...
then the G-Sensor activates (or OK button is pressed), a video file is locked. This is documented as "the recording at the time of the accident" and "the current recording" being locked (moved to another directory.)
I'm trying to better understand what this means when combining the loop recording (3 minute segments) with "the current recording."
If, due to loop recording, the current video file has only 1 second of data, and the g-sensor locks a file, is only that one second of video locked? (If so, what happens to the rest of the 3 minutes of the file that hasn't been recorded yet?) If only 1 second of the past is locked, is this really very useful?
If the above explanation is correct, wouldn't it be better to "lock" both the current and the most recent video files iff the current file contains less than a configurable (or hard-coded) amount of time?
For example (if configured to 60 seconds):
If the current file contains less than 60 seconds of video footage, the "lock" would lock both the current file and the most recent previous file.
If the current file contains >=60 seconds of video footage, the "lock" would only lock the current file.
