sanchaz12
- Sep 19, 2014
- Netherlands
- Mobius + 'B' lens, Fake DVR-207
Hi everyone!
Today I decided to replace the battery in my G1WH bought from Banggood about half a year ago. The battery originally in the device was worn out due to temperature changes and being constantly charged to 100%. Nothing new of course, most normal Li-ion and Li-po batteries have this issue under these circumstances. First, I searched the web for a compatible (super)capacitor to use in the G1WH, but could not find one. So I decided to just replace the battery.
I took the replacement battery from a rarely used MP4 player I had lying around. The old battery was a 3.7V 180 mAh Li-ion battery, the replacement one is a 3.7V 350 mAh Li-ion battery. The new battery fits perfectly in the case as it is roughly the same size and form, only a bit bigger. There is even room for a bigger one (maybe even 400-450 mAh would fit).
After I soldered the new battery to the logic board and securing the battery with some double sided tape, the camera turned on and recorded fine. No problem so far. Next, I reassembled the camera and tried turning it on and recording once more. This time weird things happened. After pressing the record button, the camera would start recording, but after about 2-3 seconds it freezes and the camera image changes to random greenish blocks and stripes. This happens about 3 out of 5 times. Pressing the reset button and turning the camera back on works fine. Only after starting a recording this would happen. I also discovered that pressing on the logic board triggers this weird behavior, when the camera seems to record as it should.
As pressing on the logic board triggers this behavior, it seems to be some kind of 'loose contact' issue. I checked all the wires for shorting, but everything seems to be fine. I tried 're-seating' the display cable in it's socket, but the problem remains.
Could this be the result of pressing the battery on the logic board? I tried not to press too hard, just enough for the double sided tape to secure onto the battery. But maybe I pressed too hard, and something on the logic board now has a 'loose contact'. Or am I looking in the wrong direction, could it be related to the different battery? This does not seem to be a relevant issue, as the voltage and type is the same, only a bigger capacity. With most electronics, replacing a battery with a larger capacity should just work fine.
If you have any suggestions or even have experience with the same issue, please let me know!
Greetings,
San
Greetings,
San
