Gaps in video
Petey
Hello all.
Pretty regularly I see the yellow triangle (exclamation mark) icon in the display along with the red circle record icon. I find that I have big gaps in the video. Meaning, when I view the clips, it will have a recorded clip, then there will be many minutes gap, then another clip. I assume the icon means warning or a problem and the video is not being recorded.
What does this icon mean, and why is the recording not seamless all the time the vehicle is running?
This is in the US btw. Running a AUTO-VOX B40-C in a 2008 Ford full-size van.
Do you have G-sensor set to high medium or low?
Did you check the RO folder? (read only)
Do you have motion detection on or off?
G-sensor set on medium.
MD turned off.
What am I looking for in the RO folder? I did not know there were clips there, without looking at each clip, could these be what's missing in the "Movie" folder?
Will do, thanks.
BTW, I checked the RO folder and most of the gaps are in there. Any reason for this?
Will do, thanks.
if the G-Sensor is triggered it will move the files to the RO (read only) folder so they don't get overwritten when recycling
Yes, basically the g sensor thinks you had an accident so it locks that file (that's the yellow triangle on screen).
Thank you!! That is what I needed to know. You're awesome!
