Garmin 56 - initial setup at boot problem
dragoshh85
Bucharest
Romania
Hello,
I'm new with Garmin dash cams, I just bought a Garmin 56 dash cam and I noticed that at every power up the camera asks for initial setup: country, language, locals etc.
My camera has 3.4 firmwareversion and I read that it needs to update via PC to 3.5 to solve this problem, but when connected to Garmin Express it says that the camera is up to date. On Android, via Garmin Drive it also says that is up to date. I searched for the update file to update it manually but I didn't find it.
Did anybody else have this problem?
Thank you.
Did you ever get GPS lock? After you set it up, leave it on until it shows the full signal strength.
Hello. I left it near a window and got 2 lines in GPS, not full signal.
Save a few message here and just take it outside and see what you get and quit playing around inside.
Are you a metal building?
What direction is the window facing N E S or W?
Is the Garmin fully charged?
Many factors affect GPS SAT Signal
I used the device in the car and after it connected to GPS it worked fine. Now it doesn't ask anymore for initial setup.
Thank you
Thank you
Worked for me as well once connected to GPS.
Hi,
I’m posting here because I found this thread while looking for a solution to exactly the same problem: my Dash Cam 56 asks me to select the country/location and language again every time I turn it on.
I saw that in your case the problem was apparently solved after leaving the camera outside and allowing it to get a strong GPS signal. I tried the same thing with mine, but unfortunately it did not solve the problem.
My DC56 was working normally when I first used it. The problem appeared after I updated it to firmware 4.30.
Since then, every time I turn it on, it goes back to the initial setup and asks for the country/location and language again.
I noticed that the GPS reception on my DC56 also seems unusually weak compared with my Garmin Dash Cam 57. The DC57 gets a strong GPS signal almost immediately, while the DC56 often shows only one bar and takes much longer to get a fix.
Because of the reports in this thread, I specifically tested the DC56 outside the city, with a completely clear view of the sky. This time it eventually got full GPS signal.
I then did a factory restore while it had full GPS signal, completed the initial setup, left it running for a while, and then turned it off and back on again while it still had a strong GPS signal.
Unfortunately, it made no difference. The camera still asked me for the country/location and language again after restarting.
So in my case, the GPS signal itself doesn’t seem to be the solution, even though the problem looks very similar to the one discussed here.
Has anyone found another solution for this, particularly with firmware 4.30? Does anyone know if Garmin is planning a future firmware update for the DC56 that might address this issue?
Thanks!
