The "flashgun on top" is apparently the GPS tracking thingie which is used to record your speedometer and direction of travel....or at least according to manual in my book....why does the rear cam need to be FHD and be included? As long as its crystal clear definition, good enough!What is the flash gun on top for?
The rear camera isn't even FHD, in fact it is not included as standard!
it's interpolated, it's not real 4k, chipset used does not support itI was able capture images at 5164 pixels by 3872 pixels which is equivelent to a 20 Megapixel camera, so I don't know how the cam is fake if it can capture beyond 4k UHD resolution size....
......soooooo those pixels are fake....? What's the real photo resolution size then...?it's interpolated, it's not real 4k, chipset used does not support it
I haven't looked but most likely they are using 4MP sensor, it's a very common setup for these......soooooo those pixels are fake....? What's the real photo resolution size then...?
I still have the unit in front of me, what do you want me to do to check for proof its fake 4k uhd? If it means opening and cracking the case open then I probably wont be able to return them since you know, I opened the case up and probably damaging the casing....I haven't looked but most likely they are using 4MP sensor, it's a very common setup for these
chipset doesn't support 4k, even if they had an 8mp sensor it still wouldn't do 4k anyway, the resolution options are a giveaway alsoI still have the unit in front of me, what do you want me to do to check for proof its fake 4k uhd? If it means opening and cracking the case open then I probably wont be able to return them since you know, I opened the case up and probably damaging the casing....
I probably would need proof if they ask for some and doubting me returning it coz "change of mind" or "buyers regret" when it's meant to be "false/misleading advertisement".
ok so then whats my excuse when I go back to the store I bought it from? Do I just say "Oh this cam you sold to me is fake 4k uhd!" and hope they buy that excuse and refund me? I bought two by the way...wanted one for the front and another for the back.... $400 there.... I guess I got suckered into the shiny 4K UHD sticker on the box and demo cam display.........................................................chipset doesn't support 4k, even if they had an 8mp sensor it still wouldn't do 4k anyway, the resolution options are a giveaway also
to be fair the people that sell these would have no clue about real 4k versus interpolated 4k, if it says 4k on the box they'll think it's the same thing
were you happy with the results, or you came looking because it didn't look right?ok so then whats my excuse when I go back to the store I bought it from? Do I just say "Oh this cam you sold to me is fake 4k uhd!" and hope they buy that excuse and refund me? I bought two by the way...wanted one for the front and another for the back.... $400 there.... I guess I got suckered into the shiny 4K UHD sticker on the box and demo cam display.........................................................
Save a frame using a good video player such as MPC or VLC, then use a photo editor to resize it from 4K to 2K resolution (2560x1440), then zoom in on both the original and resized images. If it is real 4K then the original will have more detail than the 2K version, anything up to 2x the detail, if it is fake then you will see as much detail in the 2K image as in the 4K image.ok so then whats my excuse when I go back to the store I bought it from?
I actually came here because I was confused as to why 4k uhd = 2880x2160 instead of 3840x2160 when I took a look using media info tool. This was the only mention on this site of this specific unit and thats how I found you guys after some googling and then promptly signed up to input my comments of it.... So I guess it would kinda lean towards "it didnt look right" part. Here's a sample media info report in case you guys are curious:were you happy with the results, or you came looking because it didn't look right?
General
Complete name : B:\Movie\2020_0824_145904_002.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/avc1/mp42)
File size : 1.28 GiB
Duration : 7 min 21 s
Overall bit rate mode : Variable
Overall bit rate : 25.0 Mb/s
Movie_More : DEMO1
Encoded date : UTC 2020-08-24 15:06:25
Tagged date : UTC 2020-08-24 15:06:25
Origin : ANYTEK
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 24.6 Mb/s
Width : 2 880 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.165
Stream size : 1.26 GiB (98%)
Language : English
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 96.0 kb/s
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 32.0 kHz
Frame rate : 31.250 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 5.05 MiB (0%)
Language : English
General
Complete name : B:\Movie\2000_0101_154408_005.MP4
Format : MPEG-4
File size : 72.8 MiB
Duration : 29 s 888 ms
Overall bit rate : 20.4 Mb/s
Movie_More : DEMO1
Encoded date : UTC 2020-08-24 15:44:36
Tagged date : UTC 2020-08-24 15:44:36
Origin : ANYTEK
Video
Format : AVC
Format settings, GOP : M=1, N=15
Codec ID : avc1
Duration : 29 s 733 ms
Bit rate : 20.1 Mb/s
Width : 2 560 pixels
Height : 1 440 pixels
Frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.181
Stream size : 71.1 MiB (98%)
Language : English
Audio
Format : AAC LC
Channel layout : C
Stream size : 350 KiB (0%)
Language : English
General
Complete name : B:\Movie\2020_0824_154445_005.MP4
Format : MPEG-4
File size : 755 MiB
Duration : 5 min 8 s
Overall bit rate : 20.5 Mb/s
Movie_More : DEMO1
Encoded date : UTC 2020-08-24 15:49:53
Tagged date : UTC 2020-08-24 15:49:53
Origin : ANYTEK
Video
Format : AVC
Codec ID : avc1
Width : 1 920 pixels
Height : 1 080 pixels
Frame rate : 60.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.161
Stream size : 739 MiB (98%)
Language : English
Audio
Format : AAC LC
Channel layout : C
Stream size : 3.54 MiB (0%)
Language : English
Thanks I used MPC and then MS Paint to resize and opened with windows photo viewer. Hmmmm if anything, the resized copy from 2880x2160 to 2560x1440 actually looks clearer and more defined when zoomed it! Here's a couple of attachments to see what you think of it.Save a frame using a good video player such as MPC or VLC, then use a photo editor to resize it from 4K to 2K resolution (2560x1440), then zoom in on both the original and resized images. If it is real 4K then the original will have more detail than the 2K version, anything up to 2x the detail, if it is fake then you will see as much detail in the 2K image as in the 4K image.
